Im capturing MPEG2 at 720x480 for DVD. My audio is set at 48KHz, 16 bit stereo. Im using a bitrate calculator to determine my bitrate, it wants to know what my audio bitrate is in KBITS. So, If Im capturing at 48KHz then what is my audio KBITS? Probably an easy question that I should know the answer to, but Im not having any luck figuring it out. Any help sure is appreciated.
Thanks Boxingjunkie![]()
48Khz is the frequency, nothing to do with the bitrate.
it could be any bitrate, but if you made a standard VCD/SVCD its probably 224 kbits. -
Your capture program will set the bitrate - expect it to be in the neighborhood of 192kbps to 384kbps. The 48kHz is the SAMPLE rate - not the BIT rate. To find what you are set to, just look at the capture profile.
multiAVCHD audio bitrate?
By morghe-sokhari in forum Newbie / General discussionsReplies: 0Last Post: 16th Feb 2012, 10:11 -
Difference in Audio Bitrate
By skorpinok in forum AudioReplies: 2Last Post: 29th Aug 2010, 13:47 -
Audio bitrate info
By uniks in forum Newbie / General discussionsReplies: 1Last Post: 17th Feb 2009, 16:50 -
change audio bitrate in ConvertXtoDVD
By ecc in forum Video ConversionReplies: 9Last Post: 16th Nov 2008, 22:15 -
Advice on how to downgrade the audio bitrate of a MOV file with AC-3 audio.
By InsanelyOne in forum MacReplies: 15Last Post: 13th May 2008, 23:40
