im using the option in ifoedit to split in 2 dvd-r, so my question is is there any way that i can preset the default audio an subpictures, for example the episode I movi, when you insert in dvd player star with spanish audio and or spanish subtitles, any ligth onthis will be great,
good kuck![]()
In the new IFOedit (0.932) you have the capability to add and delete Commands. Maybe if you add a in VIDEO_TS.IFO->VMGM_MAT->Play first PGC a Pre Command like : (SETSTN)Set Audio Stream Nr.: X, you can control what you want (There is another similar command for subtitles too). I already tried this with the Disney movie "Monsters" (because the first Audio Track is french) but it didn't work (I tried only on the computer DVD Player) but with this movie I had also a lot of other problems. Try it and let me know if for you works...
Good Luck ! -
it worked with movies that fit in 4.7 gb, but i tried with movies splitted in 2 dvd-rs and didn`t work, if theres another way or sugg., thnx
Don't have any ideea why is not working for two layer DVD's. Maybe is better if you try to find more about this at:
http://mpucoder.dynodns.net/derrow/
Also if there is nothing about these commands you can write an email to Derrow, the guy that made Ifoedit. He is the master of all this things...
If you find something, please let me know ! -
can someone explane tot my whatwnet wrong to me ??
i have tried to change the default subtitel but no suc6 ( with a one disc movie ) -
thanks wiespino i`ll keep trying, and let you know...
beest try the above procedure should work, just think in what youre trying to do, and thats it
How many audio tracks and subtitles are possible?
By dvdplanner in forum Authoring (DVD)Replies: 3Last Post: 5th Jan 2011, 08:46 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
No audio and subtitles
By BS82 in forum ffmpegX general discussionReplies: 20Last Post: 22nd Apr 2008, 18:23 -
adding subtitles and leaving dd 5.1 audio?
By kaoticone in forum ffmpegX general discussionReplies: 3Last Post: 21st Apr 2008, 14:59 -
DUAL Audio: subtitles and audio out of sync
By alina in forum ffmpegX general discussionReplies: 6Last Post: 26th May 2007, 15:16
