Results 1 to 9 of 9
  1. When i try to use TMPGEnc i cant open any file..its just say "can not open ore unsuported"....Dont know what do to !!
    Please need some help !
    Apr 2002
    The State of Frustration
    Nimo Codc Pack. See the Tools section.
    Hello.
  3. Banned
    Jun 2001
    UK
    KJ codec pack, see kazaa
    Don't you just hate the spy's in the new Nimo !!
  4. Thanks,,,try Nimo codec pack and now it works !!
  5. Banned
    Jun 2001
    UK
    And the Spy wear does
    Jul 2002
    Erie, PA United States
    Hey KingJohn,
    What spyware in Nimo? Is this something new in V5.0 build 8? I'm only asking since I'm still using build 7 and I'm spyware free unless Ad-aware is lying to me. Could you enlighten a few of us as to what spyware components your talking about?
    Warning! I'm baaaaaaaaack
  7. Banned
    Jun 2001
    UK
    Well Not tested everything, but you don't get DivX 5.02 Pro for free !!!
    So yes it has spy wear, included is Gator. I also found some other with Adawear..
    So Nimo lite V1 has been put together quickly as people have been complaining. Hence KJ codec pack
    Jul 2002
    Thanks for the heads up on that KingJohn. Since I'm probably one of the few who actually payed for the Divx codec I think I'm safe.
  9. Banned
    Jun 2001
    UK
    Yep, I also bought DivX 5.02 pro, but I don't mind sharing it . However if you install the Nimo codec pack and don't unselect DivX 5, then you will overwrite what you already have.
