Hi all,
is there an acm codec for mpg video anywhere? All the ones i've come across (LSX, TMPG etc) are standalone apps, whereas i need something that can be called from other apps (like when you select a codec in Vdub). Since divx installs as an ACM i was thinking there must surely be a similar installation for mpeg1 and/or mpeg2 available ....
thanks for any help![]()
El.
ACM = audio compression manager
The audio part of DIVX is mp3 (just as other music files) which is an ACM (the mp3-file gets a header which disguises it as WAV or AVI)
The video part of DIVX produces an AVI (even it is a mpeg4 "inside")-this is the only type such a codec can make and one of the reasons the mpg-programs are standalone. -
heh! thanks for that ...
i suppose the next question would be, if you can encode mpeg4 video, stick 'avi' on the end and play it back though a codec (divx, xvid etc) that understands the contents, how come you can't do the same for mpeg1 and mpeg2? It must be possible at least, even if it hasn't been done yet.
El.
Installing 32bit AAC ACM and AC3 ACD codec on Windows 7
By pchan in forum Software PlayingReplies: 3Last Post: 26th Apr 2012, 14:53 -
Trouble installing AC3 ACM codec on 64 bit OS
By Teemo in forum AudioReplies: 0Last Post: 30th May 2011, 15:42 -
Virtualdub codec MPEG-2 / MPEG-1
By Astrogirl in forum Video ConversionReplies: 19Last Post: 10th Dec 2008, 11:38 -
MPEG-2 Codec help
By Nuke Shower in forum Video ConversionReplies: 28Last Post: 23rd Oct 2008, 08:16 -
AC-3 ACM Codec na RMVB = PROBLEM
By krain_l in forum Authoring (DVD)Replies: 1Last Post: 16th Jun 2007, 17:48
