Okay, before you flame, I have searched the forums for info on the question I'm about to ask and have yet to have found a solution. I am posting as a last resort. Here it is:
I am trying to encode a particulary long movie, 3hrs to be exact, and fit it onto 2 80 min. cd's. So I make a non-standard vcd and lower the bit-rate and audio until it's small enough. No problem. after I split the finished mpeg, I get 2 mpeg files, one 733mb and one 766. I of course know from what I've read and my personal experiences, that this is fine and will fit on an 80 min disc. Nero tells me I have to turn off standard compliance and i do it but unfortunately, nero refuses to believe that the file will fit. does this have something to do with it being non-standard. Usually, I just burn standard and it fits fine but in this case my non compliant vcd loses that 100mb of leeway. Anyone who could possibly offer insight? I appreciate any time and help from the wiser.
Which encoder you're using?
In order to get Nero to burn a non-compliant VCD, the mpeg file should have its header to state "MPEG1(Non-Standard VCD)".
In TMPGEnc usually you just have to set the file to "MPEG1(Non-Standard VCD)" and not "MPEG1 System".
If you don't remember how you encoded the file, just go to File/MPEG Tools and use Merge/Split and just change the header to Non-standard and to a new filename.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 14:19 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 12:01 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 03:44 -
Reencoding to reduce the file size of an AVI (xvid) file
By DVantrease in forum Video ConversionReplies: 7Last Post: 10th Jan 2009, 21:56
