Hi I have followed this guide on two movie now. The first movie worked great, but the second movie I did didn't work so great. When I cut it the second disk was out of sync(audio). It happens right after I cut it into two parts. My dvd player does not handle svcds with 48000 sample rate so I have to downsample in Vdub. Can anybody help me on this issue. Thanks
Results 121 to 126 of 126
Hi .. ..
i just had a question about Cinema Craft Encoder SP 2.5 ... i read that u gotta buy this programm ,,,, i just wanted to kno if there is any other way to download this from a link or somethin ... If there is .. could u Plz put it in here ////// thx
I have questin for you, Lee Bear!
I try to convert avi to svcd, that I can play those films on DVD, but I dont know on which media I have to burn it. On CDR or DVD -
When u are saving the seperate parts of the movie is it normal to take up a lot of hard drive space? I Finally got it to open my avi file and now as im saving it it doesnt even get through half of the file and its up to 8GIG.. Is this normal?
Hiya Lee Bear.
I followed your guide using DVD2SVCD step-by-step and the sound was still out of sync. Maybe I forgot to click on 'No Compression (PCM)' in VirtualDub or something?
Anyway I tried again by saving the .avi and .wav files in VirtualDub then going straight to TMPGEnc with which I am more familiar and the sound worked just fine. There are just too many boxes to click in DVD2SVCD so it's a step I prefer to leave out.
(kim) -
so what's the easiest way to add my subtitles?
I'm such a noob.. I dunno how to use that script
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
best avi (divx/xvid) to cd-r (vcd) converter
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 8Last Post: 15th Sep 2008, 13:36 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 13:28 -
Convert this avi to DivX avi (GSpot Screenshot included)
By indiannawaf in forum Newbie / General discussionsReplies: 13Last Post: 22nd Aug 2007, 11:26 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 17:08
