This is the first time i try this program. After choose input and output file, a new session is open on teminal. I think it's good, but it appears an error on it, like this :
Avoid characters like ( ) [ ] { } ' " < > in folder and file names. Unix doesn't like them.
I want to thank you. It works, but i've got another problem. I convert an .avi file with mpeg2 encod. After the conversion, i can't read the file with quicktime. Do i take mpeg1 encod to read it?
thank you for your response
Mick -
The alpha version does support only .mov to mpeg-2. Soon it will also handle .avi divx to mpeg-2. You could use Divx Doctor II on the avi and convert the .mov container though. To play mpeg-2 you need VLC or the Quicktime mpeg-2 player component.
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 04:11 -
Which ffmpeg options are used behind the scenes by ffmpeg?
By roberto.aloi in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2011, 05:09 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
Difference between ffmpeg -threads and ffmpeg-mt
By Calidore in forum Video ConversionReplies: 2Last Post: 7th Mar 2010, 22:44 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 02:55
