I have been capturing VHS tapes with a Hauppauge Win-PCI for the purpose of saving them as VCD's. I have everything down fine. Capture and filter with Vdub. Encode with TMPGEnc to VCD. Using VCDeasy to burn. I am adding chapters for navigation by using "Create X Equidistant Chapters" under the chapter tab of VCDeasy. Everything plays fine, and I can use "Prev" and "Next" to skip chapters, but no chapter numbers appear either with PowerDVD on my PC or on my Pioneer DV-C503 standalone. Does chapter number display simply not work, or am I missing something?
Hello pal,
It is but normal that you don't see chapter number of VCD/SVCD/CVD upon klicking 'next' or 'previous'. You will see the chapter number if you will click a nuber key. At least it is so on my srandalone.
Take care -
'Chapters' at (S)(C)VCD aren't actually real chapters. At least not the ones you know from a DVD.
They just are kinda pin-points in the motion stream, so your player know where to jump to when you clicked the next- or prev-button, but they aren't there physicaly (the movie still is stored as 1 whole piece on the CD, so your player won't find any chapters).
So it's normal your player won't show those chapters in its led.
In most cases, a chapter only works when you're using PBC at the (S)VCD, so it's only available from VCD2.0 and up.
If you start a VCD2.0 by pressing the '1' key instead of the 'play'-key you properly won't be able to jump in the movie using those 'chapters'.
Why do some of my conversions scale on my display, others don't?
By tonyp2 in forum Video ConversionReplies: 12Last Post: 10th Sep 2010, 07:24 -
How To Change Chapter Numbers
By vomiranda in forum Authoring (DVD)Replies: 1Last Post: 5th Jul 2010, 12:46 -
srt subtitles don't display properly
By briligg in forum Newbie / General discussionsReplies: 1Last Post: 30th Sep 2009, 14:12 -
VobSub extracts subs but don't display
By den207sco in forum SubtitleReplies: 6Last Post: 23rd Jun 2009, 09:12 -
subpictures work on powerdvd but not standalone player
By domhnall in forum DVD RippingReplies: 6Last Post: 19th Aug 2007, 08:12
