Hi I really hope someone can help.
I have a very strange problem, I am very experienced in creating VCd's and they are nearly always OK for playing both in my standalone DVD player and on both my PC's
However Recently I borrowed a few VCD'sfrom a friend, after copying them using nero burning on the copy CD facility I found that these VCD's would play fine on my Stand alone DVD player, but they won't play on my 2 PC's via any program but specifically on Power DVD it says disc may be corrupt (I know this isn't the case)
I took these disks to my friends and he tried them on four different PC's and they worked fine on all his machines.
The only difference I can think that may provide an explanation is that His original disks were created on machines all running XP Pro whereas my two machines are running windows 2000 pro.
I have also found exactly the same thing on one one file VCD I downloaded from a newsgroup and burned from the Cue and Bin files. It has exactly the same symtoms as the VCD's I copied. (again it plays fine on my JVC standalone but not on my PC's)
I have a great deal of experince creating VCD's but this is absoulutely puzzling.
Anyone else experienced this problem or found a cure I'd be very grateful for your help.
Ian![]()
open up "Windows Media Player" and choose FILE > OPEN.
Now go to where it says "Files of type:" and choose "All Files (*.*)"
no go in your VCD and then into the MPEGAV folder and select one of the files ending in .dat and click "OPEN"
it should work fine.DVD to VCD made eazy
http://www.eazyvcd.tk -
I had the same prob with one of mine SVCD.
I have Power DVD installed.
When I have stared Power DVD and open the mpg file from the CD.
Power DVD Will say that the CD i corrupt.
But then I uninstlled Power DVD and install Win DVD then it work fine.
I think Power DVD has that Prob sometimes.
Saving view
By jyeh74 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2011, 14:18 -
How can i view my PC on my TV?
By awaisuk in forum Capturing and VCRReplies: 8Last Post: 23rd Jun 2009, 07:24 -
standalone dvd players: is there a file restriction view limit?
By mike69 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 4th Jan 2009, 08:27 -
View folder changes
By jyeh74 in forum ComputerReplies: 5Last Post: 20th Oct 2008, 01:18 -
Sansa View 8 GB Model how do I convert video for use with the sansa view?
By goheadtry in forum Video ConversionReplies: 1Last Post: 2nd Jun 2008, 00:01
