    May 2002
    Germany
    My new DVD-Player ist excellent and plays DVD-Audio too. According to Yamaha the player does not play SVCD´s. I experienced the following:
    - plays no self-made SVCD´s (made with TMPEGEnc with SVCD-res.)
    - plays VCD´s very well
    - plays VCD/SVCD´s very well (mpeg2-bitstream with VCD-header)
    - plays CVD´s (made with CCE with VBR and at 1/2 DVD-res.) well
    The question is: why does CVD work, while the player does not play SVCD? In my opinion playing no SVCD seems to be a software/firmware problem. If I try SVCD the movie is like slow motion with sound in little steps.
    Any idea? Thx in advance
    May 2002
    Germany
    CVD does not work OK; if the pictures move fast I have the same problems as SVCD, only parts of movies without action are well.
    Bromley, UK
    Mike100,
    As per the link below - your player doesn';t play SVCD's so I doubt anybody will have any fixes for you ...
    http://www.yamaha-audio.co.uk/dvd/dvdvideoplayer/dvd-s1200/index.asp
    Funnily enough, the lower spec model (that I have incidently - the 520) plays the lot - including XSVCD's.
    TeeeRex
