I'll get any quality gain using an adaptor to connect my VCR (composite out) to my capture card (S-Video in)? Or the quality will be the same of when i use a normal composite cable?
My VCR doesn't have S-Video Out and i use to connect to te capture card using composite.
A composite signal continues to be a composite signal, no matter how many (passive) adaptors it is fed through.
If you have to stick with composite for some reason - and not having S-Video interfaces on both ends is a good reason - use good quality cables with good quality and matching (to avoid using adaptors) connectors.
Have a nice one,
Lowlander/2 -
In fact a composite signal can be somewhat degraded when filtered into the seperate chroma and luma channels of svideo.
As mentioned, stick with a good quality composite cable.
RCA composite video on Wii but component video and VGA inputs on tv
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2010, 22:48 -
What video cards support S-Video & Composite output over VGA via adapters?
By Bix in forum ComputerReplies: 5Last Post: 22nd May 2010, 22:57 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 11:55 -
ASUS TV Tuner problem with Video in & audio adaptor
By Zpazt in forum Capturing and VCRReplies: 0Last Post: 16th Jul 2008, 15:30 -
Composite IN vs S-Video IN (using converter wire composite to s-video)
By goal in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2008, 22:19
