do u recomend the delta 12x dvdrom or hitachi 8x? delta is $20 and hitachi is $15. im gettin some good and bad reviews on the delta......
Forget what the others say, lots of that stuff is 3rd party and hearsay anyway, freggin idiots!
I just got my Delta (http://deltacdrom.com) from Staples for $49, works absolutly great, okay just fine then...
Not a problem one out of it. Use Smart Ripper (See: http://www.vcdhelp.com/dvdtovcd.htm). Make sure you:
1) Enable DMA (Dont ask how, search your answers here, the web and usegroups)
2) Use UDAM IDE cable
Will boost you from around 1.5X average to 4.5X-5X average.
Good luck, and get the Delta, its a fine drive...
<hr>
Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
<hr>
Recomend a replacement TV Card!
By c4bdriver in forum Capturing and VCRReplies: 10Last Post: 22nd Nov 2010, 14:20 -
hello forum, which program do you recomend?
By saturna1974 in forum Software PlayingReplies: 7Last Post: 1st Jun 2010, 12:46 -
Archiving DV.avi to DVDROM
By dgpretzel in forum Newbie / General discussionsReplies: 7Last Post: 31st Mar 2008, 13:53 -
Recomend a Bluray player
By cal_tony in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Jan 2008, 18:07 -
delta farce
By october262 in forum Newbie / General discussionsReplies: 9Last Post: 11th Sep 2007, 14:06
