I would like to see whether I can save the "project" I have created by VCDEasy. I find that after I have included all the files and setup all the PBC configurations, I must then burn the image file. I cannot save the settings and then continue to fine tune later.
Since this is just such a simple function, I guess it must be my fault to have overlooked it. Can anyone help me a bit?
Regards,
- David
Unless it was added in the latest v1.1.2, VCDEasy does not have a "save project" ability. The changelog does not mention anything about this, so I'd guess it's still absent.
On the main page select "Generate the XML file only" It's not quite what you're looking for but the xml will contain all the settings. You could also throw the VcdEasy guy a small donation as he often implements suggestions made by donators.
Saving in VirtualDub
By aaxpers in forum Newbie / General discussionsReplies: 1Last Post: 2nd Feb 2012, 12:02 -
Saving/capture solutions for saving off (extending) DVR
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2011, 18:13 -
Saving view
By jyeh74 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2011, 14:18 -
FF not saving passwords
By jollyjohn in forum ComputerReplies: 6Last Post: 26th Sep 2009, 08:53 -
Firefox not saving anything!
By Super Warrior in forum ComputerReplies: 7Last Post: 7th Jul 2007, 02:20
