I have a bunch of movies in MPG1 that I'd like to author to a DVD.
1) Do I have to convert them first or will an authoring program do that?
2) Which is a good authoring program to import these files to?
<-------------- Goto the AUTHOR section on the Left, there's a guide in there that will tell how to do it.
Hope that helps -
I don't think these files are VCD compliant. Can I convert them to a VCD compliant file using TMPEnc or something similar. Will it still work if they're not VCD files?
experiencing the same problem what authoring programme r u using u lead is no good from what i have read
how bout converting to dvd compliant mpeg 2 with tmpenc and authoring with spruceup trial or convert to vcd with tmpenc then follow guide
iam attempting to place three mpeg1 files on a dvdr and play them through dvd player unable to do so due to no access to .dat file on mpeg1 ?vcd
I installed SpruceUp late last night so I haven't had a chance to play with it. It seems to accept some of the MPG files I have which is cool. I'll play with it some more when I have time.
can i truncate mpeg1 video files without re-encoding?
By dullrazor in forum Newbie / General discussionsReplies: 2Last Post: 22nd Nov 2009, 15:47 -
Question how to join 4 mpeg1 files
By jimdagys in forum EditingReplies: 5Last Post: 28th Sep 2008, 21:18 -
any tool for converting vob files to mpeg1?
By sumeshkri in forum DVD RippingReplies: 8Last Post: 18th Feb 2008, 22:22 -
question about how to author DVD from several mpeg1 files
By jimdagys in forum Newbie / General discussionsReplies: 11Last Post: 5th Jan 2008, 07:49 -
Can't play MPEG1 video files!
By gummybear00 in forum Software PlayingReplies: 1Last Post: 27th Aug 2007, 00:04
