    Dec 2001
    Singapore
    Hi,
    I encoded a SVCD in TMPEnc Plus 2.56 and it completed successfully.
    However, when I tried to cut it using the merge and cut function in
    the program, it gave me a direct show error.
    I could not open the file nor edit it at all.
    I tried to install PowerDVD 4.0 but it did not help.
    I also set the Direct Show priority to 4 but I still get the same result.
    Appreciate some good advice.
    I'm using Windows XP Pro.
  2. I have never been able to get TMPGE to edit its own SVCD's. I'm usuing WIN98 so its not an OS problem. If they come out to big I just remake them again smaller. No problem with VCD. Hopefully someone will have the solution.
    Calif
    Maybe you set directshow Multimedia plugin too high..try to decrease priority to 1 or -1.
  4. Banned
    Jun 2001
    UK
    Originally Posted by Gallen
    Hi,
    Try another version of TMPGEnc. 2.58 is out Although 2.56 should also do the job, I use it all the time to covert SVCD to VCD and merge&cut works fine with any Mpeg 2 it makes...
    "I tried to install PowerDVD 4.0" did you or did you not ? Other mpeg 2 codecs can cause a problem (Nimo)
