Not bragging but damm, it takes like 25 minutes for me.
I upgraded my P.C from a Pen 2 400mhz(which took 2 and half hours to convert) to an Athlon XP2100XP, which cost up to £900 for the whole P.c, but damm is it worth it.
Results 1 to 12 of 12
but how long is the movie your converting. you can get the xp2100 chip from ebuyer.com for £100
It totally depends on lentgh, type of movie, frame size, filters, original format(DVD or Captured Avi), conversion method(CQ_VBR, 2 pass VBR, etc) etc.
If I do a 50 min captured clip in a 2-pass it takes about 100 min when resizeing and encoding to CVD(mpeg-2) on my 1600 XP when using TMPGenc for everything. -
the movies are using an average of 125mb,, and they are capture avi files which i'm coverting to mpeg.
@cdtplug, i meant £900 for the whole system, not only the chip(lol), that included a 80gb hard drive, 512mb, e.t.c. -
it takes me about 4hours to convert a 700mb divx movie backup to a dvd mpeg2. i have a xp2000 chip and 100gig harddrive pc. i built this myself and with a dvd burner came to £700
set your cache setting on tmpg.It will speed up your 2 pass VBR.
options>enviromental settings>CPU>cache settings
When you are a lucky bastard and have a dual Pentium,you should turn on the :use multithread button.
Ore you could use cce,4 times faster....
I was going to ask this very question. But I don't think the "standard" has been set. How about 1 hour of AVI converted to 1] VCD and 2] SVCD. Assume using all the default settings in TMPG. Please post your computer details as I plan an upgrade soon and want to know what I'm looking for.
Me: VCD = 1 hour AVI takes about 8-10 hours
SVCD= afraid to try
Saw you own a smashing 366 Mhz,well that explains your 8-10 hours....Originally Posted by fmctm1sw
I have a 1.0 ghz Pentium 3 256 mb RAM with a 32MB Video card on a Inspiron 4100.
It took me 9 hours to encode Star Wars Empire strikes back
and the audio went off sync
I've just about given up on everything.
what am I doing wrong
The audio also gos off synce even when doing 22 minute episodes of Family Guy
I'm beggining to hate this stuff, and I already own a pioneer 104, and a bunch of other stuff
Please help"Sleep-
Those little slices of Death;
How I loath them." -
Your ADS Instant USB seems to get a bad rap as most other USB sevices too. USB was designed with low speed periferals in mind (keyboard, mouse, etc). BUT, I know there's folks here that have had success with it (assuing that device is what is causing you issues). Maybe you could pick up a cheap tv tuner and see what it does. Your computer is FAR superior to mine, so there no doubt in my mind your computer is capable.
nope I've only converted one actual capture for dvd. The rest is just downloads that I want on dvd.
I've had good luck with my Instant USB. But I know people give it alot of shit. For me though its great for having a labtop
Any other ideas?
come on 'oh great ones. I know you know some tricks
"Sleep-
How long is a piece of string? The conversion time depends on so many things besides the power of your PC, which is of course very important. For example, converting from DivX is much faster than converting from DVD. Other factors that can affect the speed are tweaking the environmental settings, choosing different motion search precision, and using the various filters. The latter can dramatically increase encoding times.
FitCD thinks 43 minute video is 2 minutes long - ditto TMPGEnc
By natrap in forum Video ConversionReplies: 3Last Post: 2nd Aug 2009, 22:02 -
cannot covert .ts file to anything
By vespera in forum ffmpegX general discussionReplies: 4Last Post: 29th Jul 2009, 01:05 -
Hours to covert to mp4
By oldfolk999 in forum DVD RippingReplies: 2Last Post: 28th Jan 2009, 17:55 -
Covert 4:3 DVD to 16:9
By phowe in forum Video ConversionReplies: 2Last Post: 8th Jan 2009, 16:26 -
How to covert .lqt to Mp3
By mlong30 in forum AudioReplies: 3Last Post: 10th Aug 2007, 19:14
