  1. I've been working on this file for a while now, trying to get a working VCD to play on my dvd player. I have made several working vcds with the same CDR adn same player. Its just that this file doesnt seem to be playing. I convered it using TMPGEnc and EO. I've worked with Virtual Dub, I've trie dto burn the bin file, but it still doesn't play. It doesnt even read the disc. It jsut says no disc. Any ideas?
  2. Go here and see if your player has any media or encoding limitations:
    http://www.vcdhelp.com/dvdplayers.php
    Live every day to the fullest as if it is your last, because someday it will be.
  3. WEll some people have said that the memorex cd-rs atha tI use don't work, but I've gotten a several to work on them just fine. Let me try a different brand with his file and I'll get back to you.
    Mar 2001
    Antwerp - Belgium (Europe
    Are you sure the mpg is (S)VCD compliant?
    If you've managed to create playable (S)VCD's in the past for your standalone dvd-player, then it mostlikely is caused by the mpeg which isn;'t wright.
    Try re-encoding it, otherwise try a demux and mux using (S)VCD.
