When I use DVD decrypter,, and the files are copied to the VIDEO_TS file, the ISO is zipped into RAR format, so I have to unrar it. I am a newbie, but this does not make sense, is there a setting I am missing or something? I'm trying to backup a DVD to a DVD-r thank you
i dont know what the problem may be, but why don't you try uninstalling winrar and see if you get the same problem. if you don't get the same problem, then re-install winrar and try again. just a suggestion
