What's the best app out there to convert a Divx to Mpg so I can burn it to a VCD? I know it's probally a lame question but I've tried to do this with Tmpgenc (ver. 2.53) but get "cannot open or unsupported" when trying to select the Divx file as the source.
Any advice would be very helpful.
Thanks in advance.
TMPGEnc is great.
for that error thing, look to your left, click "how to - newbie" then "tmpgenc common problems"As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
If you have a missing codec it wont open in TMPGEnc, also check this out.Originally Posted by blazert40
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
how can i convert .mov to .mpg?
By johnnylonghair1 in forum MacReplies: 4Last Post: 6th Apr 2008, 12:30 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47 -
How to Convert 1280*720 DivX to a less dimensions DivX
By firas_hashim in forum Video ConversionReplies: 9Last Post: 27th Jun 2007, 09:33 -
By chalutz in forum MacReplies: 7Last Post: 11th May 2007, 10:51
