  1. I have a svcd file which has video (mpeg2), audio and there is also a file for subtitles.
    After I separate the video and the audio (using bbDemux) how would I convert the audio to vcd (not svcd) standard. At this point I only wnt to manipulate the audio. After the audio gets changed I would then like to joint the 2 (MMT works great for joining). Finally I would like to add a file for subtitles.
    philip
  2. The standard says:
    VCD 1.1 must cbr mpeg-1, layer II (mp2) at 224 kbps
    VCD 2.0 must be mp2 at 128, 192, 224 or 384 kbps
    Mplex will mux in sub-title tracks also, I don't know if it's been successfuly done on mac yet.
  3. If I first just want to manipulate the mpa file by turning it into aiff/wave/...and then use MMT to join the fixed audio file together what would I use? That is, what program will manipulate the mma file in order to change it to meet the standards quoted. I know you can use Mplex to handle both the audio and video at once but is there nothing that will just handle the audio alone ? Sorry about all this. It's all seems much more complex than I would have imagined.
    philip
    Originally Posted by Ross
    The standard says:
  4. Convert MP2 to AIFF
    This is very basic, but works. Copy and paste into Script Editor then run. OK to change AIFF to WAVE at bottom of script.
    --start script
    set this_mp2 to choose file with prompt "Choose MP2 file ot convert:"
    tell application "iTunes"
    convert this_mp2
    quit
    end tell
    set this_mp3 to choose file with prompt "Choose the new MP3 file: Home/Documents/iTunes/iTunes Music/Unknown Artist/Unknown Album"
    set the new_file to choose file name with prompt "Enter a name and choose a location for the new AIFF file:"
    tell application "QuickTime Player"
    open this_mp3
    export movie 1 to new_file as AIFF
    quit
    end tell
    --end script
