I found a solution to recording and playback problems using cheap media.
-Disable or uninstall antivirus programs
-IDE ATA/ATAPI controller set to DMA
-Create a master copy on branded high quality DVD-RW disks
-Use disk to disk method to transfer data to Cheap DVD-r media.(it's better to use only one DVD drive for both source and destination drive. Use a fast drive for temp files.
-Set write speed to 1x and set Data and Audio Read Speed to 1x
This worked in your standalone on unbranded cheap media?. Cause i got alot of expensive coasters trying to get the right discs that work on my samsung MC20.
Yup. It worked. Before using this method, the DVD-R played well in only one player (Sony DVP-S345 standalone player). Now cheap media also plays well in DEll Latitude C800 DVD drive and Pioneer DV-535k standalone player.
Looking for some cheap Dual Layer Bluray media (BD-R DL) ..
By ahmadka in forum MediaReplies: 0Last Post: 26th Mar 2011, 22:07 -
cheap solution required for monitor
By devdev in forum ComputerReplies: 4Last Post: 13th Apr 2008, 10:36 -
What drive(s) CAN reliably burn cheap 8x DL media?
By miamicanes in forum DVD & Blu-ray WritersReplies: 20Last Post: 16th Feb 2008, 19:09 -
Best Solution for DivX/XviD on a TV (Apple TV or Media Center Extender)
By fletch407 in forum Media Center PC / MediaCentersReplies: 2Last Post: 30th Jan 2008, 01:08 -
Need new (cheap) capture solution-what to get? Are TV tuner cards any good?
By wickeddvine in forum Capturing and VCRReplies: 1Last Post: 16th Jun 2007, 09:50
