  1. Just Curious...I've got an mpeg2 file that's 736mb in disk space. I've heard that when you use 80min cd-r's you can fit 800 mb of space. Well when I try to burn this I add the file into vcdeasy and the available cd space goes red and it doesn't work when I burn. I there something i'm doing wrong that is not letting me burn or is it just vcdeasy.
    It should fit on a 80 min cd if you burn in SVCD Mode. If it is dvd mpeg2 file you can try to first multiplex with svcd settings using tmpgenc or bbmpeg www.vcdhelp.com/faq#multiplex
