I received a disc from a friend which had the following folders on it:
Cdi, Karaoke, Mpegav, Segment, and Vcd
I put it into my DVD player (Apex AD-1500), the menu came up and I finally found the Music01 to play and played it. It had no sound and it was very 'pixelated'.
So, I copied the Music01.dat file to my Mac, converted it to mpeg using VCDGear and then used Toast Titanium to burn a VCD (at 2x speed).
I put that into my DVD player, hit play and it worked fine (for 11 minutes until the audio started skipping, but that's another thread).
Anyway, I looked at this disc on my computer and it only had three folders: Cdi, Mpegav, and Vcd
So my question is, what was it that I originally received (the CD with five folders)? I can't seem to find anywhere on this site where it talks about what folders are present on a disc for any of the formats (VCD, SVCD, VDVR, etc).
yes it is a vcd
http://www.vcdhelp.com/vcd.htm#struct
the avseqxx.dat can also be named musicxx.dat. -
Yep, when I burned my own CD, Toast named the file avseq01 instead of music01.Originally Posted by Baldrick
Is there some reason why my DVD player would play one but not the other? And is one 'format' more 'liked' by DVD players than the other?
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 12:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
