Im trying to use the bit rate calculator to determine my bit rate. But when I try to open it, it says that I need to download the Java Virtual Machine. Im running XP. But it says that XP wont let me download it. Is there anywhere I can download it? Or is there a simpler way around it?
Thanks Boxingjunkie![]()
Results 1 to 9 of 9
You can always use some other bitrate calculators
http://www.vcdhelp.com/tools.htm#calc -
Hi There,
I Had the same problem as well with WINXP PRO.
It Seems that Micrisoft have stopped supporting it in there OS.
Anyway you can download one of the other calculators that Baldrick give you the link to, OR...
You can download Java Virtua machine from here....http://java.sun.com/getjava/download.html.
It's what i done when i was using WINXP and it worked perfect.
I'm now using WIN2000PRO and it has java built into it -
Unless Im missing something, none of them will calculate for DVD's will they? They all show SVCD and DIVX. Thanks for the help.
Boxingjunkie -
yep the VCD calclator will do DVD as well
Just change the setting from SVCD to DVD -
Yeah MS stopped giving the download a while ago, its a part of their fight with SUN. Their site will give you da good stuff
Bit Rate Vs Quality
By kashif71 in forum Video ConversionReplies: 20Last Post: 21st May 2010, 00:19 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53 -
Bit Rate
By shapper in forum Newbie / General discussionsReplies: 10Last Post: 2nd Jun 2008, 14:04 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48 -
the right bit rate
By nojee in forum Video ConversionReplies: 5Last Post: 10th Nov 2007, 03:00
