i tried to join an mpg4 avi, and it came in 5 different parts, each is a separate file that is to be viewed separatly, can i still join em? virtual dub says they're not from the same video clip so i can't join em.
Sure you can. Install AviSynth and turn it on in the registry,
Copy the following text to WordPad or NotePad. Change the path, filenames, and resolutions, repeat the command as many times as needed where applicable:
AVISource("c:\video1.00.avi").BicubicResize(320,24 0)
+AVISource("c:\video2.00.avi").BicubicResize(320,2 40)
Save the file as a .avs file, and save.
Load it into VDub (using all files) and run.Hello.
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 17:55 -
Cannot join two clip in Virtual Dub
By s_joy09 in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2011, 16:15 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
How do I dub over the audio on a video clip?
By SpeedKills07 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jul 2007, 06:19
