I just switched back from WinXP to Win2K and I have encountered a problem with MPEG files playing. Both on Windows Media Player and QuickTime and all other programs, I can see the video, but there are some strange flickering vertical lines and dots all around. No idea what it can be.
I have a Geforce 2 NVIDIA video card. I'd be very glad if anyone of you could help me
best regards,
michuk
If this is a fresh install you need to add all the codec's back. And may need to update WMP
What kind of codecs? I never installed anything except for divx codecs, but it's for AVI files. AVI work okey. I have a problem with MPEG. What kind of codecs do I need for that with Win2K? I didn't need any with WinXP nor Win98....
And it's not WMP for sure, cause the same problem appears under any of the media players..michuk -
Mpeg 1 and Mpeg 2 codec's by the sound of it. Normally Windows media player will search and update any missing mpeg 1 codec's, but you need to install Mpeg 2 yourself. Power DVD 4, will install some for you.
Also installing the wrong codec's can upset the balance, if you installed SMR (Angel potion) get rid of it. Nimo "lite" should be tried, unless you want to install them manually. Nimo full, has spywear in the codec's (DivX 5.02) KJ codec pack is better !, but no Mpeg1/2 yet
Does WinXP fix a known Win2k problem?
By bevills1 in forum ComputerReplies: 6Last Post: 1st Mar 2009, 00:34 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Win2K hangs during booting... :-(
By spiffy in forum ComputerReplies: 3Last Post: 9th Apr 2008, 14:23 -
windows explorer in win2K
By fjmr in forum ComputerReplies: 10Last Post: 4th Oct 2007, 18:37 -
What does win2K need for WinMediaPlayer9 to work ?
By DBenz in forum Software PlayingReplies: 2Last Post: 1st Sep 2007, 12:21
