ok, i've been working hard on this one, and got a little stressed out with it.
but i changed heaps of stuff and it now supports selecting different program chains so you can rip all the other stuff on the DVD.
You can download it from http://www.eazyvcd.tk
Hope you all enjoy. =8-)
Version 1.06
- Fixed problem with BeSweet not normalising, now it is working great.
- Now using BeSweet to encode audio to mp2 (cos BeSweet does a better job)
- TMPGEnc no longer encodes the audio, it just muxes the mp2 file from BeSweet.
- Now using vStrip and not SmartRipper as vStrip does a better job.
- Ripping different Program Chains is now supported. (longest chain is selected by default)
- Now shows the audio language and info in the Audio Track box. (first track is selected by default)
- Video Format is now selected automatically, but you can override.
- Aspect Ratio is now selected automatically, but you can override.
- No longer have to select DVD drive. The DVD drive is now selected automatically.
- Fixed problem where Eazy VCD would run in the background when closed.
- Installer no longer installs an ASPI Layer.
- Added even more error trapping.
- Made the GUI look a bit better.
Known Bugs
- The first time you use Eazy VCD and it get's up to the TMPGEnc Encoding stage, TMPGEnc will show you a Splash screen, you must select the "Don't show this dialog again at startup" check box and then click ok. You will never see it again.
DVD to VCD made eazy
http://www.eazyvcd.tk -
I'm looking forward to this one mate, the last version was a cracker already!
Cheers
:P -
you're not the only one "cjedward"
the last one was excellent, so i'm looking forward to this one as well!
keep up good work! -
Thanks guys.
I'm glad you like the software, and I hope you like this version too.DVD to VCD made eazy
how do i download these??
By XBucklawX in forum Video Streaming DownloadingReplies: 1Last Post: 18th Jan 2009, 21:25 -
where to download DVD/ VCD covers and labels?
By pglenn in forum Newbie / General discussionsReplies: 5Last Post: 20th Jan 2008, 04:36 -
The Vital Message - General Fiction, download ebooks, free download, The
By spacek77u in forum DVD RippingReplies: 1Last Post: 14th May 2007, 01:29
