I would like to change the default sound encoding settings to 192kbs when using the Project Wizard in order to squeeze a little more space out of a disk. I know there are many templates and have used the unlock option in TMPGenc but my preference is to use the project wizard which always defaults to 224kbps. I have edited the mcf files by changing all occurances of 224 to 192 but this has not helped. Any pointers would be appreciated.
You're just a tube full of gas and a box full of tin, you show me your charms and I want to come in.
Just load the normal VCD template, load unlock.mcf and then save it as a custom template in the root template folder.
You will be able to use your new settings in the Project Wizard next time you start TMPGEnc.
DVDFab defaults to second drive as target
By audax in forum Authoring (DVD)Replies: 1Last Post: 21st Nov 2009, 23:44 -
how to reset a Philips computer monitor to factory defaults
By sarainelkins in forum ComputerReplies: 1Last Post: 27th May 2008, 14:42 -
So you've got to much change...
By Faustus in forum Off topicReplies: 28Last Post: 13th May 2008, 10:00 -
how to get a better quality web video than youtube defaults
By spyonmenot in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jan 2008, 03:42 -
how do i change from +R to -R
By offensekilla in forum Authoring (DVD)Replies: 1Last Post: 29th Aug 2007, 07:55
