I am try to convert a couple of dat. files into avi files, mainly because the avi is compressed and takes up much less room. I used vcdgear to convert them to mpg files but i can't seem to get beyond that point. exstream changed it to an avi file larger than the origional dat. file, and Flaskmpeg and virtual dub keep giving me error messages. i can't even open the mpg file with virtual dub. please help![]()
^_^
sohma -
.dat files will load straight into Vdub and TMPGEnc without the need to convert them.
If Vdub has a problem, use TMPGEnc Browse (*.*) > .dat
Then use File > output to file > AVI > Codec etc -
hi, i got it to convert to mpeg using the program u showed me, but could not convert it to avi. am i supposed to use the same program to convert it to avi or another? virtual dub dosen't work at all.
^_^
sohma -
When you want TMPGEnc to convert to AVI, Select File-->Output to File...-->AVI file.
Hello. -
Yes, select File > Output to file > AVI > Video > Setting >Originally Posted by sohmaou
Chose a Video codec to match the source, or use DivX low motion, with a bitrate of 400.
Also chose a codec for audio > MP3
If you miss any of this out, you will have uncompressed audio and video -
hey, thanx for all who replied. I did find everything except the audio conversion stuff. I couldn't find the mp3 in the audio section so i ended up with uncompressed audio. Do i have to download anything for that? again, thanx everyone
^_^
sohma -
If you cannot select MP3 for the output, you need to install a Codec pack. Nimo lite from http://nimo.everwicked.com/
Or search Kazaa for the KJ Codec pack -
Hey thanx, i did get it converted to an avi file from dat. I did have a question, i thought it was gonna b compressed, but the resulting avi file ended up larger than the origional dat file. Is that normal?
^_^
sohma
What is the DAT file?
By coody in forum Video ConversionReplies: 3Last Post: 22nd Mar 2010, 20:29 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 12:57 -
.Dat File?
By niteghost in forum Video ConversionReplies: 3Last Post: 24th May 2009, 21:38 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 19:31 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 22:06
