Hi when i try to convert a AVI to VCD or SVCD the speech is a little late sometimes when i play the VCD/SVCD. How could this be? and do u guys have a solution for it?
PS. When i make rip my own DVDs to AVI i never have that problem. Except when i download them
Hi
Have u tried FF or RW the movie you have downloaded. ??
Check the synch of the d/l movie b4 u think it is TMPGEnc.
I've downloaded many a Divx movie which the video looks great but when u use the seek function the synch is all over the shot.
Chances are its your source and not the program.
Fozzee -
If the AVI sync is ok, use Virtualdub to extract the audio as a WAV.
Then use the WAV as the audio source in TMPGE."Today is only yesterdays tomorrow" -
As far as I know u only have to extract the audio if it's divx.
You may be using the wrong settings to extract the audio in Virtual Dub. Check the guides on this site.
Hope it helps.
Fozzee
TMGEnc Xpress - no sound
By deanst2 in forum Authoring (DVD)Replies: 3Last Post: 2nd Jun 2010, 18:27 -
TMGEnc Xpress Not enough memory issue
By hawk123 in forum Video ConversionReplies: 0Last Post: 10th May 2010, 19:21 -
audio encoding: tmgenc dvd author 3 vs. tmpgenc plus
By cL0N31 in forum Newbie / General discussionsReplies: 0Last Post: 7th Jan 2009, 00:25 -
TmgEnc DVD Author Menu Problem
By powerkoala in forum Video ConversionReplies: 9Last Post: 25th Sep 2007, 14:19 -
Tmgenc DVD Author
By powerkoala in forum Video ConversionReplies: 10Last Post: 19th Sep 2007, 07:02
