I was using Tmpgenc. There were sound in the original AVI but not in mpg after conversion. The setting I went for inc video and sound filespointing at the the same AVI. When it was actually processing the conversion, the stream type at the bottom of right habd corner points at the 4th option (ie system - video+audio). I just don't understand why no sound. Thanks.
You need to find what kind of audio the XviD has and then extract as an uncompressed wav to input into TMPG. The method of extraction will depend on the type of audio. Often XviD has ogg audio, for which you are best using Graphedit.
Best way to batch convert xvid/avi files to mkv/x264 files?
By gaikokujinkyofusho in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 07:31 -
AVI to Xvid conversion
By Davjefdunn in forum MacReplies: 4Last Post: 16th Sep 2009, 10:48 -
.divx to .avi XviD conversion?
By Benhermies in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2009, 19:15 -
Vista beginner needs help with video conversion! Xvid to VCD with subs
By Joakim_A in forum Video ConversionReplies: 2Last Post: 23rd Sep 2007, 03:59 -
splitting *.d2v into separate files for xvid conversion
By greenbag in forum Video ConversionReplies: 15Last Post: 22nd Sep 2007, 18:14
