    Aug 2002
    MiddleShire UK
    does anyone know the biggest import mpeg2 file size that spruce up will allow because im trying to add a 4.2 gig file and it locks up on 100% and just hangs
    Someone on this forum told me that for ulead movie factory the max is under 4 gig is spruceup the same ?
  2. It's probably not the size of the mpeg2 that's the problem. Either try demuxing the mpeg and importing them seperatly (give them both the same name with different extensions, import the .m2v and spruce will import the sound file right after) or cut a few frames off the end of the mpeg. Either will probably fix your problem.
    Aug 2002
    MiddleShire UK
    Thanks bel, its ok now i just had to be a bit more patient it loads in the end and made a good movie, i was having a bad day with a few programs i was trying to use for the first time.
