I used to make great Svcd's from divx. Recently they all seem to have intermittent audio sync problems when playing in my dvd player. Thinking something could be wrong in the player, I tried some that were made 3 months ago and they played fine.
I use Vitual dub 1.4.10 to extract the audio and TMPGEnc 2.57 to convert the divx to mpeg2. Could up grading to these newer releases from older cause this problem. I am stuck for an answer on this one.
Mark
Are they made from the correct frame rate that you are converting them to . ie. 25fos to 25fps and not 23.9>25. Litterally is your DVD player a PAL and you are using a NTSC film, or visa versa.
When you Vitua Dub to rip the audio are you putting the full precessing setting on as well as selecting 41000 in the compression or conversion tab.
Full Processing, Conversion from 48kHz to 44Khz.
Nothing has changed in the way I do things. The only thing I could think of was a version change. I know it is not my method.
Mark
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
Intermittent Ghosting
By koberulz in forum RestorationReplies: 1Last Post: 27th Feb 2012, 11:14 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Intermittent sound on mini-DV capture
By adamj_ut in forum Capturing and VCRReplies: 5Last Post: 17th Nov 2009, 18:47 -
Intermittent Jerky Playback Question
By Maikeru-sama in forum Video ConversionReplies: 11Last Post: 12th Oct 2007, 08:30
