When creating a normal VCD, is there any way to have one small video play, and THEN have it go to the menu?
I'm using Nero Version 5.5.8.0 if that makes any difference.
Hey cool, shadow puppets.....
That just says how to make a normal menu. I'm asking how to make a video before the menu. For example, the finished product would work like this:
1.VCD is put in player.
2.Small video is played.
3.Menu to access other videos is shown.Hey cool, shadow puppets..... -
I have done this before.... in VCDeasy, just import the files you want inthe order you want. then make sure that under the Options tab that 'Use Playback Control' is checked. NOw go to the interactivity tab and make the first video play, and "then on timeout" set it to the MPEG for your menu that you want. go to that mpeg file (in the 'play item' pulldown menu) and to make it loop set it to "play forever". then just change the numeric keys and link them to the vid files that your menu is linking to and voila!
sorry if the explanation is a bit rushed!
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 03:44 -
Better Menus
By clinging2thecross in forum Authoring (DVD)Replies: 3Last Post: 13th May 2011, 06:10 -
Menus folders or sub-menus
By GymDad in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 9th Nov 2008, 08:43 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 11:07 -
Menus
By mingul in forum Authoring (DVD)Replies: 4Last Post: 19th May 2007, 07:42
