Hello,
I just ripped a dvd and reconverted it to DVD using Tmpeg.
What I would like to know is can you make an auto run movie like a vcd on a DVDR?
What I mean is can I just drag and drop the DVD file onto the TS folder using nero like a vcd?
I use nero to make vcd's and all you have to do is open the vcd video template in nero and drag and drop the mpeg file on the vcd file and burn it and it will play in a stand alone player.
So I wanna do the same thing for a DVD.
I Guess what I am asking is,Is there a way to burn a converted DVD file to a DVDR without having to Author it or make menus.
As I find authoring and menu extra's a pain in the ass..
Well Thanks for the help.
You must first use DVD authoring software before you can burn your movie to a DVDR. In the authoring software you should be able to tell it to begin playing immediately after it is inserted.
Disabling auto-play
By videohalp in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Jan 2012, 09:28 -
dvdr auto arrange
By JekylHyde in forum ComputerReplies: 6Last Post: 2nd Dec 2009, 08:34 -
How make auto-play jpg-foto-DVD for standalone DVDplayer?
By onidarbe in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Oct 2009, 03:20 -
DVD menu exists in video ts folder but won't auto play upon insertion
By perceptionist in forum Authoring (DVD)Replies: 3Last Post: 2nd Aug 2009, 05:13 -
Authoring an auto play DVD or editing an exsisting ONE to auto play
By theewizard in forum Authoring (DVD)Replies: 22Last Post: 16th Mar 2008, 11:06
