Hi there, I've captured videos from PAL VCR at 352x576,RGB24,Picvideo Q19 using Virtualdub.
1. Do I have to deinterlace it first using Vdub's internal deinterlacing filter before resizing it to 352x288 to get better VCD result with CCE ?
2. Why's that using RGB24 to capture videos consumed less processor power than YUV in Virtualdub ?
Thanks.
This quote comes fromLuke's Video Guide, wow, what a reference!When Should I Deinterlace?
As I mentioned earlier, each field in an interlaced video comes from a different point in time. Therefore, interlaced video can be thought of as running at 60 fields/sec or 50 fields/sec rather than 30 fps or 25 fps. An interlaced display is capable of displaying each field separately. Because of this, an interlaced video will play much more smoothly than a progressive video when using an interlaced display. Therefore, if you're planning to watch your output video on a TV (through an SVCD, for example), it's best to leave your video as interlaced.
On the other hand, if you want to watch your video on a progressive computer monitor, it's a good idea to deinterlace your video. Because a progressive display updates both fields of a frame at once, you won't see the increased smoothness of interlaced video that occurs on an interlaced display. Instead you'll see interlacing artifacts, which don't look very good. That's why it's recommended to deinterlace your video if you'll be watching it on a computer.Hello.
What deinterlace method to choose for virtualdub?
By muffinman123 in forum Capturing and VCRReplies: 7Last Post: 6th Sep 2011, 15:06 -
VirtualDub Deinterlace Filter yadif vs blend
By kreg in forum Capturing and VCRReplies: 1Last Post: 22nd Jul 2011, 13:42 -
Virtualdub + Deinterlace?
By CactusMan in forum Newbie / General discussionsReplies: 10Last Post: 17th Jan 2010, 20:09 -
To deinterlace or not deinterlace...
By Nilfennasion in forum MacReplies: 4Last Post: 4th Dec 2008, 01:46 -
VirtualDub Smart Deinterlace filter vs Xvid option
By StealthKing in forum DVD RippingReplies: 16Last Post: 17th Aug 2007, 12:37
