OK folks, here's my situation.
I created my first succesfull DVD using the ATI AIW 7500. MMC 7.5 had an option for Video CD Encoding. I used this, and was able to fit about 3 hours of video onto my first DVD RW Disc. Only problem is, the audio was terrible, because it had to be converted to DVD standard.
So, I upgraded to MMC 7.5, wich has DVD Audio included. I then encode the videos in ATI's DVD 'Medium' Option, wich is ; MPEG 2, 352X480, NTSC(525), 3.00 MB/s, 48.000KHZ, 16Bit Stereo.
however, in using the software that came with my HPDVD200i Writer(Sonic, My DVD), it ALWAYS adds about 100 MB's to the file. It never did this the first time around, so what am I doing wrong? Especially considering that this encode I am using is 'dvd compliant?'. The Files I am importing into MyDVD are only 440MB's in size, so I should be able to fit at least 8 onto one DVD+RW disc.
Any ideas?
Results 1 to 1 of 1
low end quadro is 5 times faster than high end gaming card
By deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 16:42 -
Dvd burning problems and frustration
By zubiri in forum Authoring (DVD)Replies: 14Last Post: 27th Sep 2010, 21:19 -
PAL DVD to NTSC DVD: CCE is changing resolution (720x480 to 720x576). Argh.
By Colmino in forum Video ConversionReplies: 2Last Post: 9th Jan 2009, 20:15 -
'jitter' frustration on DVD
By hondo2160 in forum Authoring (DVD)Replies: 3Last Post: 21st Aug 2007, 21:16 -
Low End Video Card w/ adapter vs. Low End DVD player
By enter8 in forum Media Center PC / MediaCentersReplies: 6Last Post: 20th Aug 2007, 16:45
