is there a link to website or some info only a flawless way to convert DVD->VCD/SVCD without any audio sync problems?
less than jake, wooo hooo!!!!!
i have tried all the processes on this site and they haven't worked except i haven't tried the pocess where i use mjpeg tools, how would i do that process because it say i have to compile mjpeg tools and idk how to compile things? I have apple developer tools if that help to compile
thanksless than jake, wooo hooo!!!!! -
a new process i am considering using is this:
1)-osex to rip dvd -> vob
2)-mm2c to go from vob -> mov
3)-ffmpegx to go mov -> svcd
this is just a general outlook of what im thinking about doing. i would, of course, have to use something to take audio off vob, probly go to aiff or mp3, then add that to my mov, which i would save, then put into ffmpegx. once i get the chance, im going to play with this process and see how it turns out. although, u must know specific facts about your source, probly most importantly the fps, in order to achieve the right results. this is just my opinion of what seems to be the quickest and easiest way to go from dvd -> svcd. good luck with whatever method u use! -
i have tried this method before but i get stuck on the ripping part because everytime time i trty to rip in OSex( dont kno how to use extractor) my comp crashes and i have to restart. i have trashed my prefs for OSeX but thats all i can think of that would mess it up. Any help on how to fix that would be great.
Why you may never find an easy way to sync dvd rips
www.lukesvideo.com/telecining4.html#why
Your best bet may be find somewayto output VLC to a stdout file or chain the audio & video to encoders. Or wait till MediaPipe evolves to dual channel. -
Ross-
any suggestions on how i do this?less than jake, wooo hooo!!!!! -
lessthanbake I have only looked at this briefly. In unix, output of one process can be passed to the input of another by piping. (process1 | process2)
Open Terminal and type (or copy and paste)
cd /Applications/vlc.app/Contents/MacOS
then
./vlc -H
then try
./vlc -l
Note the macosx interface, sound and video module. The full download at vlc.org may have more output modules.
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 17:38 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
