Whenever I have finished burning my cd's using vcdeasy I play them in my apex player and as long as I don't fast forward or anything the audio and the video stay aligned. But if I fast forward or rewind the video jumps a 3 to 4 seconds ahead of the audio. Is there any way to fix this or do you not fast foward vcd's.
Thx
Are you pressing the right button ?. It should play from the stop, do you have a pause button then ?
i had the same problems with my pacific 1002, and in these forums was the answer, u have to change the svcd header into a vcd one, u still have the svcd quality, just u can also FF/RW, just says vcd on front of player..
Here how.....
Step 1:
If your svcd is in a bin file extract the mpeg out using vcdgear. If its the mpeg you got go onto the next step
Step2:
Open TMPGenc and goto File>MPEG TOOLS then Select the merge and cut tab select in the combo box Video-CD (The first one of the two) Then click add load your Mpg file into the program select your output file and click run.
Step3:
Open your favrite authorware software and burn if using nero click video cd drag the mpg into it(THe new mpg) then once its finished checking it it will say that theres somthing wrong click the button to turn it off (first button down) then click burn.
Now you will be able to watch svcd quality on your dvd players
Fast forwarding and rewinding a tape before capture?
By justin81 in forum RestorationReplies: 4Last Post: 14th May 2010, 16:41 -
Video freezing when fast-forwarding.
By xcodyj in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2010, 03:45 -
Viewing during VCR fast forwarding/rewinding
By spinmonk in forum Capturing and VCRReplies: 12Last Post: 30th Aug 2009, 18:30 -
ogm's fast forwarding
By CommanderZero in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2007, 23:23 -
fast forwarding flvs with vlc?
By majax79 in forum Software PlayingReplies: 2Last Post: 20th Sep 2007, 13:54
