i'm encoding a divx.avi i open it in tmpgenc and encode to mpeg2 with the kdvd template but i have also tried normal tmpgenc templates but the problem im getting is the video jerks anoyingly at different points every say 5 seconds on pc and both my dvd standalones
is there a program that will sort this out i have all my settings correct in tmpgenc
cheers theskid
Your probably got a playback problem on the frame rate conversion, try matching the fps of the input to the output
Load VCD template, Load unlock template, change fps on output to match input, you can also try the 3:1 pull down.. But if your player wont play those disks this wont work. -
thanks but tried all different fps
but i noticed when i put avi through wizard it enabled inverse telecine option so i tried it doing that and guess what it plays smooth now
what was wrong with the .avi then get a few like this not all -
God knows what people make out there, I think sometimes they want you to watch it but not copy it !!
Just like "How do I protect the CD I made"
TMPGEnc Authoring Works 4 Menu Help Needed
By VOYAGER2009 in forum Video ConversionReplies: 1Last Post: 15th Apr 2011, 12:37 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
Material with interference problems needed
By sylvanez in forum RestorationReplies: 2Last Post: 28th Oct 2007, 14:21 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
