Is it possile to draw lines in Photoshop 6 like in Paint.
I'm making lightsabers and i want strait core lines.
If possible, how?
every heard of help files?? Its amazing what one can learn if they actually look for the answers to the questions themselves.
I did look. That's why I'm asking. I searched for lines and "line tool" and nothing came back.
So then I decided to ask. -
Well, I assume that you are using the rotoscoping technique to get the lightsaber, and I know that you can do the wide lines in photoshop 7, but I assume you can probably do it in PS6 too. I did it with great results. It just takes forever.
Hi,
There is a line tool in Photoshop 6.
It is located in the same catagory as the rectangle tool ( Not the rectangle marque selection tool at the top), it is located under the Type tool button, and to the right of the pen tool. There should be a button for shapes and one that is Line. If you open up the options of the line button (double-click) or open the options pallete from the top it will give you the ability to change the weight of the line. Or you could always use the pen tool if all else fails.
Later,
Ronnie
Easiest way to convert .sub to .srt? maybe some command line tool?
By clinique in forum SubtitleReplies: 2Last Post: 23rd Feb 2010, 12:42 -
Command line tool to demultiplex video
By lovyagin in forum EditingReplies: 6Last Post: 20th Dec 2009, 12:43 -
Command line tool to take AVI samples
By Dean C in forum EditingReplies: 6Last Post: 9th Sep 2008, 05:55 -
Command line text overlay tool
By lmundy in forum LinuxReplies: 3Last Post: 13th Jul 2008, 13:58 -
Command-Line Tool to Join Videos?
By RobDude in forum EditingReplies: 1Last Post: 4th Jul 2007, 12:53
