Hi Iv just started using Power VCR II along with my Pinnacle PCTV Rave card, to capture from TV and VHS, and I get good quality caps but no sound? Iv turned sound options on and line in is not muted?
Results 1 to 9 of 9
Hi
In "audio source" I am assuming u have line in selected for playback and recording?? And that your audio lead is plugged direct into the line-in of your soundcard?
If the answer is yes to this I'm stumped. What soundcards do you have???
Fozzee -
Hi
I assume you have installed the program and the update patch???
Fozzee -
now iv got sound, but its out of sync with the video!
no update i dont think, where do u get that from!? Thanks for the reply tho.
FOzee: I have Power VCR 2.0, that Patch wont work coz its for v3
my audio is still way outta sync
Hey, you solved my problem!! Thanks!
I was getting no sound at all in PowerVCR with my ATI TV Wonder VE. The patch fixed it. It even says: "Fixes sound problems with ATI TV Wonder" when you download it.
Power director surround sound
By werdna99 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Dec 2011, 14:33 -
No Sound JVC HR-9600U S-VHS VCR
By snocap820 in forum Capturing and VCRReplies: 3Last Post: 8th May 2011, 11:42 -
Power adapters for external capture cards
By pinetop in forum Capturing and VCRReplies: 0Last Post: 5th Mar 2011, 00:34 -
I have no sound in Power Producer recording
By AmandaJo in forum AudioReplies: 7Last Post: 13th Apr 2010, 16:01 -
Cant get sound from recorded TV in Power Director 7
By tuiluvva in forum Newbie / General discussionsReplies: 2Last Post: 30th Jun 2009, 05:11
