i am Burning with prassi Primo DVD with my A03 and with WINDOWS XP
i have been burning 1 game for 5 hours and it's only reached 40% can anyone please help, this is driving me crazy, Can anyone tell me what options i may have to change or anything PLEASE! aaaaarrrgggghhhhh
there is one option in burning that maybe suspect which is "VERRIFY EACH ROUND" could that be it?
i burnt another game previous and it did the same thing through untill 30% ( which was about 2 & half hours) then all of a sudden it just took off back to normal burning speed.
Please, all answers are appreciated. Could it be my hard drive? it's only a few months old? i checked the DVD writer with the device manager and it said working properly!
thanks in adavance - please help me save my hair, ha ha
is this a copy protected game by any chance ?
may have something to do with it ... -
i am sure that you can just simply make the gi. Image then burn,i have done many before, so i don't understand why this is hapening, it copys over fine but then it seems to be getting the data extremely slow to burn
any other suggestions?
thanks
also if i want to burn a DVD movie that is under 4.7 can i do a straight make the image then burn without changing anything ( encoding audio and video)? -
see this thread - these people sure know thier game copy stuff
http://www.vcdhelp.com/forum/viewtopic.php?t=111527&highlight= -
Thanks i went over and checked it out, unfortunetly that was for pc, my fault i should have stated that it was a console game.
i have reinstalled the program and i tested & burned a game and that seemed to work so i will try another and see how we go, it's an expensive beer coaster i will tell you that much, i should have a matching set for the house soon, ha ha (hope not! fingers crossed)
thanks again for the reply's..
i love this forum should be called everythinghelp.com. many smart people in here to learn from.
cheers again
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 15:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
