i convert a avi file into mpg by using TMPG Enc, frame rate using 23.976 which is match the source avi file, however, after converted, i put the *.mpg file into nero to burn VCD, it say the file is not a VCD 2.0 format, and after burnt, i can't watch in all player....
chat all : how can i solve it???? does any s/w help to fix it?
Thx!
You made a non compliant VCD, does your player play those
Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Video-CD NTSC (MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps) -
Just normal DVD player......
it seem my player can't play the format which you mention,
if can't play those, how can i solve it? -
Pritt,
Have you encoded the mpeg with the following settings:
Video-CD NTSC FILM (MPEG-1 352x240 23.976fps CBR 1150kbps, Layer-2 44100Hz 224kbps).
This setting is VCD compliant, but beware that some dvdplayers doesn't
support this framerate.
vcd4ever. -
If it can't play them, you need to load a VCD template, try the PAL at 25fps....Originally Posted by Pritt
How best to convert/get rid off VCD/DVD/HDVD9?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2010, 01:17 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 06:35 -
How can i burn a DVD or VCD with subtitles?
By Krimoon in forum Newbie / General discussionsReplies: 2Last Post: 25th May 2008, 16:41 -
how to convert and burn avi to vcd with cusoft
By brandon334 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Apr 2008, 19:49 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
