When u have made a dvd compliant mpeg2 with TMPGenc say around 4 gig whats the best way to get this baby onto dvdr with all the vob files and such. which tools are best ?
Results 1 to 13 of 13
you will need a authoring program and a burning program ..
prob the simplest way is here
http://www.vcdhelp.com/dvdmoviefactory.htm -
Im having problems with ulead movie factory its only picking up 90 seconds of my 4 gig dvd mpeg2 ive posted another thread about this but im waiting for help still
DVDMF has a problem with files larger then 4gb so if you rerender or cut it to about 3.8gb it should work.
Uncle Bud Thank u, i'll give that a try, Do u think they might fix this with a patch cos its been real anoying.
Does anyone know of an authoring program that will let me use the full 4.2 gig it seems like such a waste of space to only use 3.8 g when u could have up to 4.3 gig on the dvd-r disk, I think DVD work shop has the same problem because it opens nearly all the film but chops of the last 20 mins or so, i Guess that will only allow 3.8 aswell ?
Smurfpacker. Maestro is a VERY powerful authoring program with a relatively easy learning curve.
Thanks for the links, ive got nero, and i downloaded dvd cutter just got to sus it out now
SpruceUp is the easiest and I think one of the best, unless you go with the really high end ones like scenarist or maestro. It's definitely the one to start with and learn. It's not sold anymore, but there is a demo on the web and a key generator can be found around if you look in the right places
smurf- i had the same problem with ulead, it only recognized the first 2 minutes of a 4gig copy if men in black that i made. nothing i did helped, i demultiplexed and re-multiplexed and nothing, so I ended up using another piece of software for that one movie (maestro) but i haver to say, my favorite by far is still ulead for its simplicity.
andy -
I like Sonic ReelDVD for its perfect results, great functionality and the best compatibility with different players.
Spuce is good it recognised the whole file no prob and made a good movie, the only thing is it reconized my writer ( pioneer A04 ) , but wouldn,t let me write to it and i had to use nero to burn the title set, its ok but a bit jerky when the camera pans from left to right or vise versa but im not sure if it my conversion, but it doesn't do it when i play it on the pc only on my wharfdale stand alone player.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14 -
HD Mpeg2 Conversion for DVDr use on HDDVD players
By dildatron in forum Video ConversionReplies: 3Last Post: 25th Jun 2007, 18:09
