Withe several differnt AVIs, tmpgenc keeps crashing my PC. it just freezes up and nothing will work unless I hit reset. The progress could make 5% or 90 % or anywhere in between. There appears to be no pattern. I have a 1gb proceesor with 256 DDR ram and 20gb drive, running W2K.
Please help if you know whats up.
what version TMPGenc?
always post as much details as you can - it might help someone who knows the answer
Do you run any softwares in backgound when you encoding with TMPGEnc like Anti virus, Firewall? Try to disable all and encode again see if that help?
Actually I don't really think this is the cause though. In my old system which is only 466 MHz I had Norton Anti virus and Norton internet securities which all know they're resource eating. And I have no problem at all when encode with TMPGEnc and also run these 2 program over night.
You can also check if your avi files have bad frames which will cause the problem. Or maybe try same avis in different system to see if problem is your system or the files.
Freezing Problem!!!!!!!!
By vickynash in forum Newbie / General discussionsReplies: 20Last Post: 26th Jun 2010, 21:37 -
ScenalyzerLive Freezing
By JoRodd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 31st Mar 2009, 09:36 -
Tmpgenc keeps freezing
By WinSpecToR in forum Video ConversionReplies: 6Last Post: 12th May 2008, 00:08 -
Computer Freezing up
By ruknabard in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2007, 17:52 -
TMPGENC DVDAuthor 3 freezing up during output process
By CodySave in forum Authoring (DVD)Replies: 1Last Post: 21st Jul 2007, 11:57
