Using TMPGEnc I get only a blank screen on the outputted mpg file, The sound is OK any Idea's as to where I am going wrong?
I guess you have the codec ?
Try this
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4 -
hmm, No, I Know you are missing a codec. I had the same problem
Get the NIMO codec pack:
http://nimo.everwicked.com/
Good luck
Na, stopped recommending Nimo, it has spy wear within the codec's.
Download the "KJ Codec Pack" from Kazaa
After you check the VFAPI
Black (blank) screen after converting MKV to BD with TSMuxer & ImgBurn
By Jijital in forum Authoring (Blu-ray)Replies: 3Last Post: 4th Oct 2011, 08:24 -
Blank screen when playing video on 'full screen'
By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 20:40 -
Sorry if already posted about converting .avi to Blank DVD's
By tcory in forum Video ConversionReplies: 3Last Post: 26th Jul 2011, 18:30 -
Getting blank screen (with audio) after converting MKV to Bluray ..
By ahmadka in forum Blu-ray RippingReplies: 6Last Post: 30th Apr 2010, 09:40 -
Blank video when converting MP4 to AVI DivX
By vidnov in forum ffmpegX general discussionReplies: 16Last Post: 12th Mar 2010, 18:45
