Is there a way to get Virtual dub to use MPEG-1 MPEG-2 file capture? The best Codec that works for me right now is the PicVideo MJPEG Codec which has about 25-50 dropped frames for every 500.
I have a Duron 750 with 192MB ram and Gainward GE Force 2 MX 400 twinview/vivo golden sample video card which uses a Phillips Decoder. I use the VFW wrapper.
Does anyone have suggestions on how to get my dropped frames down.
Try using AVI_IO instead. I was getting a similar drop rate in VirtualDub. Switching capture apps resulted in close to zero.
i also use mjpeg and the droped frames are >5
it used to be 30+ because i had my ati-v app running so i closed all the start up progs and saw a huge improvement
is AVI_IO any good? because i have used the capture prog that came with the tv card but it only supports uncompressed
to tweak win98 starup stuff
Free more ram
run msconfig and click on the star up tab uncheck junk like messenger, icq, ati virus prog, etc. (if you don't know what it is, don't uncheck), but first check the program if it can be disabled
then on explorer click help about and it should tell you the memory available
Compression codecs lost! Where do they come from anyway?
By Artas1984 in forum Video ConversionReplies: 4Last Post: 22nd Apr 2013, 01:52 -
Lost in a sea of codecs...
By Walczak Photo in forum Newbie / General discussionsReplies: 3Last Post: 16th Feb 2011, 18:12 -
I have suddenly lost the ability to convert to DiVX with Virtual dub
By DaneClark in forum Video ConversionReplies: 6Last Post: 8th Jul 2009, 08:16 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
Some questions regarding Virtual Dub
By smackyourfupa in forum DVD RippingReplies: 3Last Post: 5th Nov 2007, 07:00
