  1. I had problems with the audio when converting divx to xvcd but after a while the result was good, audio was in sync and everything was O.K.
    So i got a xvcd file with 48K audio and when i tested it everything was fine but after i burned it and played it with my sony dvdp-ns305 the audio was out of sync..
    I burned it with nero 5.5 as a non-standard vcd at 4x speed on a cd/rw
    help please
  2. hmm when i play it with powerdvd its all fine.. so i guess its my dvd-player..
    is such kinda problem caused by a to high audio bitrate?
  3. Display Information :
    Display Mode : DirectDraw
    FourCC Code : YUY2
    Surface Type : Overlay
    Video Attribute :
    Video compression mode : MPEG-1
    Source picture resolution : 352x288 (625/50)
    Frame Rate : 23.98
    Bitrate : 2.55Mbps
    Audio Attribute :
    Audio Coding mode : MPEG-1
    Sampling Rate : 44.1kHz
    Number of Audio channels : 2
    Bitrate : 128 Kbps
