Is there a widget available for the Pan dmr e20?
thanks.
Well I have a Pan DMR-E20 and have taken it apart and looked at the insides no Widget in there, motherboard, CPU, Ram and DVD Burner with IDE cable and Computer power cord and thats about all, oh yes Pan Chips for the DD and DTS decoders also.
Now, I have the Sampo 631CF DVD Player with a hacked bios so no CGSM, thats about as close as I can come to a widget. -
A widget is a device which turns a in only firewire port into a in/out port.
You can get them for panasonic camcorders, and other makes too. -
thxkid: Is the hard drive replaceable with a larger one? Have you examined the drive under Windows or Linux to see if it can be duped? This would be great as the E30 and HS2 could then get cheap larger drives put into them much like the Dishnetwork Dishplayers can have their small drives replaced with larger ones...
Oops! Was thinking of the DMR-HS2, not the E30 which has no hard drive...
Replacement for Tivo NowPlaying Widget?
By whoisquilty in forum MacReplies: 7Last Post: 22nd Oct 2012, 08:45 -
Panasonic DMR-EH50 and Pan. DVD-RAM disks inconsistent
By rehoboth in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Mar 2012, 22:50 -
Pan to Next Slide
By stefanj in forum ProgrammingReplies: 0Last Post: 3rd Dec 2011, 10:26 -
What is Pan and Scan?
By janlafata in forum Newbie / General discussionsReplies: 7Last Post: 15th Jan 2009, 22:27 -
Pan through a still
By towtruck in forum EditingReplies: 17Last Post: 15th Oct 2007, 11:06
